Any suggestions on what to try next with my failing BitZ flashlight?
I've been EDC'ing it for a few months now and its been working flawlessly on primaries, until the other day when it fell out of my pocket. Before I could catch it, the BitZ received its first usage scar and now my light won't turn on consistently. If I can get it to go on in any twisty mode at all, I have to then give it a good thump in the palm of my hand to get it to fully light up the rest of the way.
I've tried other brands of primary 123 cells -- with no better luck. I've also tried bending the internal leaf spring to make it taller with no change. I've also cleaned all the threads to remove any excess lube with no change.
Many times now the BitZ will not even light up no matter how tight I make the head. Thumping the side of the light in my palm doesn't do very much when the light is failing to even illuminate the led at all.
I'm running out of ideas to try and Lighthound no longer seems to sell the BitZ flashlight, which is where I bought mine from, so I'm not even sure I could send it back to Lighthound for some warranty repair work.
