BK E1e/E2e head with XM-L goodness
Boston
I did this build for a friend who was looking for some seriously pocketable power. It is a T6 XM-L driven by a 2.8A 3 mode driver powered by a single rechargeable lithium cell. The reflector was just something I had sitting around the parts bin and the head was bored to accept the pill. The MCPCB is an 8mm board to fit in the tiny pill. I used aluminum because I was tired of machining copper and because it is a lot lighter and the copper snugs are pretty heavy, the aluminum makes for a lighter head. When used on burst use on high works just fine for heat dissipation. While not photographed well the negative contacts are soldered on to the back of the board and are supported against the aluminum snug. Making a solid negative contact is generally the challenging part of these builds. Arctic Silver thermal epoxy will be used to secure and transfer heat to the body once the build is tweaked.
Parts layout
Will you be offering this mod? If so I have a E1D and a E1E I'd be interested in having converted. Awesome mod by the way. I'm subscribed, wanna see this bad boy finished.
This mod may be offered, on a single cell body the output isn't as bright as on a 17670 cell but it does make for a rocket.
If you decide to go ahead and do commissions please let me know the details. Hope to see some updated pics soon :-)
I'm the one he built this for. What a pleasant surprise too, since we had discussed possible builds, but had nothing planned yet. I have to source a body and tail still, but once I put everything together I will take some photos of the light and beam shots. This light made an otherwise shitty week much better. Thanks Roman!!!! :thumbsup:
A quick stop at the engraving shop before the post office...
xveganxcowboyx pictures make mine look like they were taken with a disposable camera. I look forward to the beam shots he'll take.
foxtrot824,
nice mod, I've done two similar ones, I agree the negative connection between board and light body is difficult. could you explain your process in more detail, I'm interested in any other solutions that others have tried, thanks
I don't have many great photographs of the negative contacts points but here are a few. They are kinda like little wings or tabs soldered to the back side of the driver.
This is a similar snug in an e-series also sporting the same shinning beam driver (yup xpitxbullx, a shinning beam special).
Foxtrot824,
Thanks for taking the time to post the additional pics, I really like your solution to the neg. connection
No problem. The key I've found is making sure the "tabs" or "wings" are supported from the back side as they will get crunched when screwing down a head.
Here is a close up on that one
Here the Aleph body is superimposed on the unit to show how it would look minus the head.
