Bright EDC
Robe
Oklahoma
Well my last attempt to post got swallowed up. Rabbits. In short: I was after a Moddoolar Slim with the tailstanding end, crenulated bezel (not critical), with modes, and a Nichia 219. It seems like that's not an option atm, so I am looking for something similar. I'd love your thoughts and experience.
Rob
--- This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
--- Essentially unlimited. (Wording makes me uneasy!)
3) Format:
--- I want a flashlight (hand held/self contained).
4) Size:
---TINY - Every day carry (2-4 inches).
---SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
---Really want the Nichia 219. I LOVE the look.
6) Manufacturer:
--- I would like a light from a specialty manufacturer (Possibly limited run/Custom).
--- I am interested in assembling my own components. (I don't have a ton of know-how here.)
--- Whatever. Leaning towards rechargables. Have none, but like the idea.
--- I want a separate/stand-alone charger (this involves removing the batteries to charge)
--- I want something impressively high, but with modes. I'd love a moonlight mode and a general edc level rather than an on/off 1 bazillion lumens.
Any of these:
--- Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
--- Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
--- Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
--- close up to really far away ;)
--- not a concern
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
---Slightly Important (Walks around the neighborhood).
or
--- Very Important (Camping, Backpacking, Car Glove-box).
(Waterproof a bonus!!)
--- I want a tail mounted switch (found on the majority of today’s high end lights). Tailstanding, please.
--- I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
--- I don’t care.
15) Water resistance
--- IPX7 (Waterproof to 1 meter/30min)
or
--- IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
--- In house (temperature/climate controlled environment)
--- Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
--- Pocket/belt clip
--- Crenulated bezel
Eagletac D25 A or C (AA or CR123) Ti with N219. Might be a wait though.
The Nichia head and Triad tail are out of stock at the moment. With all due respect to EagleTac, it isn't in the same league. Buy something to distract you and wait for the Moddoolar.
I have no idea, but I knew that it existed, and thought I would throw it out there for consideration, while waiting as yoyoman suggested.
