Melissa2007
I often work at night and need a bright flashlight for reading address numbers on homes and apartments. Sometimes they even do them in black numbers on brown backgrounds, things like that. :sick2:
I need to be able to read them from the car while out in the street.
I'd like to find the brightest possible flashlight for under about $100, that uses lithium batteries, preferably the largest ones they make? Like maybe dual 18650's?
It needs to run for about 5-6 hours on a charge. It's ok if it gets dimmer after 4 hrs but not a whole lot dimmer.
But the biggest thing I need is one that comes with a drop-in charger, so I don't have to remove the batteries to charge them after each night out.
I go out about 4 nights a week and it would be a real hassle having to mess with the batteries after each night out.
I've been using a Lightwave 4000, which is marginal at best, if I keep fresh alkalines in it, but it does last a lot of hours on a set of them. But I really really need something brighter, it just won't cut it for reading addresses from the car, most of the time.
And I do want rechargeables with a drop-in charger unit, so I can just put the whole flashlight into the charger each night and not have to remove the batteries.
I've heard that the Luxeon series of LED's are much brighter than this Lightwave 4000 that I have, and that there's a Cree LED that's even brighter than those now?
