Brightest 9007 bulb
jimbo231
Ontario, Canada
I want to buy some new bulbs for my 2001 explorer and they are 9007's. I don't want to spend too much but want them to be way brighter then the oem's. I'd like a far throw as well as a wide beam. I'd like the light to be on the whiter side. What's my best bet?
You won't be able to change the beam pattern, but have you heard of Philips Xtreme Power? They run around 40-45 bucks a pair. Perhaps someone with actual personal experience with different bulbs will have better suggestions :twothumbs
I put the Philips Extreme Power bulbs in my 04 Ranger (same 9007 type) last year and it makes a marked difference. Upgrading the wiring harness to thicker wire to the headlights will also help reduce power loss in the cable and increase brightness.
Avoid the blue tinted bulbs. This is a gimmick to make the headlights looks like HID. It does nothing for brightness and actually can reduce brightness, not to mention looks fake anyway.
9007 headlights on the Ford Exploder aren't much to write home about. Another option is to see if the Ford Dealer lists headlights for export markets, since a lot of domestics use a different (generally better) headlight in other countries. Just make sure they're for countries where left hand drive (like ours) are the norm.
The most effective upgrade is a custom wiring harness.
You need the most voltage to the bulb, and the least resistance to the ground.
A 9007, by definition has upper and lower bounds.
So unless you are going to put something with a stock wattage low beam, and a 100 watt high filament, don't expect miracles with just a bulb swap.
Yep, get the Philips Xtreme Power 9007s. Candlepower has them, among other vendors. They are the best 9007s currently available. Make sure the headlamps are in good condition; if the lenses are at all clouded or fogged, polish and recoat them. And make sure they're aimed carefully and correctly.
The suggestion to put in relays and better wiring is good advice; Ford's headlamp wiring tends to be far too thin for efficient power supply to the bulbs.
The suggestion to use bulbs with a higher-than-stock-wattage filament is bad advice for numerous reasons; the nutshell version is that it will cause more problems than it solves.
Ford does not list export headlamps in their North American parts catalogues. It looks as though that body style of Explorer might have been sold with a European-compliance package (see this ad) but you would have to go to great effort and expense to get them, and they would likely not be better. Different, but not better -- Ford's North American operation, like GM's and Chrysler's, have long tended to cheap out on their European-market compliance equipment. There's an attitude in the US industry that the rest of the world should just adopt US standards (in reality the reverse is the case, the US should adopt the rest-of-world European standards). But most of the export-spec headlights for US-model Ford vehicles are bare-minimum in performance and construction quality...probably not worth bothering with.
I know this is an older thread but just out of curiosity, what problems have you seen?
There's a good and accurate sum-up of the issues with high-wattage 9000-series bulbs over here (PDF) with more interesting (and technically accurate/sound) technical info sheets here. Bulb filament placement and position accuracy is super important. The filament geometry is specified with micrometer (tenth of a millimeter) tolerances, because more than that and the beam pattern focus gets totally destroyed. Check out this comparison of a single H3 fog lamp with a bulb with accurate filament placement (top) vs. a bulb with inaccurate filament placement (bottom). It's from a document translated from its original language, hence the awkward English:
