Broken Surefire L6 Lens
rx78gp02
Few days ago i shattered the lens on my L6. I'm soo upset right now, but Does anyone know a good place to order a replacement lens?
My guess its going to have to be custom built.
Have you tried emailing/calling surefire about this? They might be able to help you out even if it's been discontinued.
You should call SureFire and explain what happened.
If your KL6 bezel is unmodified I'm sure you'll ne able arrange to send it back to SureFire for repair or replacement.
that might be a problem.
the emitter has been upgraded with an MCE.
This KL6 once belonged to the great Dafabricata.
The glass shattered enough that its very easy to undo the retaining ring of the unit. Would probably be faster for me to change it then go through surefire with this guy.
any idea?
erm...you'll have to take the KL6 head apart to access it...the window is bigger than what can be measured on the outside
this wouldn't happened to be A00584 would it?:green:
If so I once owned it, alongside A06130
If you want to do it yourself, get the measurements and see if http://www.flashlightlens.com/ have something for you.
thanks for the suggestion. just what i was looking for!
The KL6 i'm using is A05260
when it shattered, the outter retaining ring came loose so it was very easy to turn by hand. Good luck i guess?
if anyone is also wondering to replace their Surefire KL6, the lens is 38mm in diameter.
thanks for the help guys.
i knew i was too hesitant to celebrate.
flashlightlens.com doens't have the lens size i'm looking for.
any other ideas?
i'm thinking canablizing an M3 head for the lens as a worst case scenerio.
