Budget C cell lights?
BillG
Harrisburg PA
i would like to get a good budget 2c light. one or two levels of light would be fine.
side switch would be ideal!
any suggestions?
thanks..................Bill
Can't help much here, but I am aware of two similar lights. First is the 2C Taskforce from Lowe's. The latest version used a Cree. I have a similar light from Advanced Auto that uses a 3W Luxeon that may still be available. It was $20 vs. $30 for the Lowe's light. Neither light is multi-level and both have tail clickies. It might be tough to find either of these.
Geoff
For a side clicky, the only thing I can think of is the old incan C-cell maglite which is still sold at many places. (You might as well go to the D cell maglite and get the led) Otherwise, there is the C cell version of the duracell daylite. It is a tail clicky one mode and it is pretty bright for the price. Its pretty easy to find and might be your best option. Why a C cell? The AA leds are fantastic and if you really want super long life and something hefty, you should go to the D cell anyway. (The 3-D Maglite led is super cheap on amazon right now).
I was also going to mention the taskforce and duracell daylite.
Also I believe there is a rayovac sportsmen extreme c cell light.
I agree that a C cell will be hard to find.
A C battery has the same voltage as an AA or AAA, so its only advantage is that it lasts longer.
Since LEDS are so efficient, a 2xAA light can produce the same light as 2xC batteries and still have good runtime.
Therefore, for the higher end lights, the C-battery is somewhat obsolete.
I'm actually with you on this one, I like C cells for size and capacity, plus it's easy to substitute AAs in a pinch. Unfortunately, I don't really have any good suggestions though. I have a c-cell mag with the MagLED luxeon part, and a target/river rock 2 C cell light that was on clearance a while back. Both are budget-minded, single level lights, but both the MagLED drop in part and the river rock lights are discontinued. Don't see many options for c cells, which is a shame.
I forgot about the Rayovac Sportsman. It is 3C cells, but it is a side clicky, albeit one mode. You can still find it easily.
The only C cell I have is a Mag 3 x C with a dropin (can't remember if it's Terralux or Diamond). I like the size and shape, but it wasn't that much of a budget buy at UK prices.
I can't speak for the original poster, but in my opinion, everyone should have at least one C-cell light or battery upsizers so that you can use C-cells in a D-cell light.
The reason for this is that in an emergency, AAA, AA, and D batteries sell out quickly, but C batteries almost never sell out. You should have at least one light that can use them (either directly or via batter upsizers).
--flatline
Latest version of that light is 2 mode (high and medium). Same form factor as original version.
The problem I found is some stores have stopped carrying them altogether.
I have a 2C Mag with the Mag LED upgrade.
I have a 3C Mag with an SSC-P7 upgrade.
I find a C torch or a fat AA like the Dorcy Gelbrite fits my hands better.
Lumapower has the Mentor. 1C/2C/3C XRE/XPE/MCE.
None of the lights I mentioned can be considered budget.
All of the good choices have been mentioned.
The Advanced Auto Parts 2C is a good one. One of the most compact C-cell lights out there. Uses a tailcap switch, but very handy. Smaller overall than a 2C Maglite modded with the older, non-rebel, LED.
I'm not familiar with that one. Do you have any pics and can you give us more info on it?
I was glad to see Flatline's comment on emergency avalibility of C cells. Those of us on this discussing this are not going to find themselves out of batteries, but I have frequently suggested that non flasaholics buy a C cell for their emergency supply kit. I used to live in coastal NC and pre-hurricane the stores would be wiped out of almost all batteries execept C cells (and a few 9 volts).
My river rock nightfire cree 3 watt is a great light. I got it for around $30. Its one mode, Cree emitter based, OP reflector, tactical momentary switch, good throw, your basic light. Does everything mag does wrong, right. :D
No idea if theyre still at target, but if so, its the ideal 2xc light.
I second the Duracell Daylite, also.
I just love when people tell someone that their choice is no good (i.e. don't use C-cells, use D-cells). As someone who also enjoys the use of C-cell Mags (w/ Mag LED & Malkoffs), I, for one, find the feel of a 3 C-cell Mag to have an almost perfect "feel" in my hand. I also have many D-cell Mags, but MUCH prefer the "feel" of the C-cell lights.
Another C-cell light to consider is the Streamlight ProPolymer C cell,
http://www.brightguy.com/products/Streamlight_ProPolymer_3C_LUXEON.php
Not exactly budget, but I have seen it in the mid to high $20's range lately. It is a nice light & I keep 1 with my BOB, along w/ a C-cell Mag.
My .02 FWIW YMMV
River Rock brand lights haven't been sold in Target for more than awhile now, unfortunately.
