"c" type head for leef body
Saranic
Fey Folks
who makes a comparable "c" type head that will fit a leefbody?
I plan to use a malkoff device and a RPM tail
Suggestion
Apart from SF, you can find cheap Chinese made clones
all over the net.
I think Lighthound use to have them, if not then Ebay will
Thanks labrat,
I have one of those from lighthound and I could not get it to work with my Malkoff Device on a SF body, I did not try it with a leef. Ill give that a try
Any other Suggestions are welcome
The Solarforce bezel is deeper than the Surefire bezel, and might require a shim to make electrical/galvanic contact with the body/tube.
Check if the drop-in is stuck tight when the bezel is screwed down without batteries in the tube.
If there is a a slight rattle, you do need a shim!
This is also sometimes an issue with Surefire tubes, and drop-ins without the outer spring.
