A break-in charge is defined by being a long slow charge, that will always include "slow overcharge" , so there would be no reason whatsoever to have topping included. You could say topping is already included, and then some.
Which brings up another question I have.
Really what is a good Break-in MaH ammount to use for This charger and Eneloop 2000mah batteries?
If the actual rate is 2Amp pulsed very short, to do this C9000 (psudo) break-in, why would I need 16 hour? The original Idea of 16 hours, was at a Slow Rate (actual rate) , the charge acceptance is lower, or the charge efficency is low. But if the real rate is 2amps pulse, then there is no slow rate, With low charge efficency. Why are we shooting for 60% over, when we dont have low charge efficency here?
Because I have Other chargers, i have not applied the Break-in on the c9000 yet. I cannot bring myself to do it "normal" when there is nothing normal about the break-in method used in the c9000.
I am thinking (oh no) That I can adjust the Total MaH that I input to the break-in on the eneloop cells for 2 reasons.
1) The eneloop has a good charge acceptance at many rates anyway.
2) Why would there be low charge acceptance at a Pulsed 2A
3) Everybody knows that 16hours at c/10 is probably overkill in this situation
So I am sorta looking for a break-in number to put in, that would be relative (for this charger) for what is actually needed, to reduce the overcharge or the crasy in this situation for unnessiary 16Hour?
