I've been using an 8AX for 3 years now at work on a daily basis. I bought it after the charger was redesigned to not kill the batteries, the indicator blinks(my good fortune). My original B90 lasted a year after being recharged about every other day, so I bought another, it wasn't so long lived. Number 2 started dying after 6 months so did I call in a warranty with SF? Heck no I got some Sub C NiMH 3300 cells and rebuilt both sticks.
I also opened up my charger and noticed the letters "NiMH" on the pcb next to "NiCd". I'm OCD about opening everything to see how it works even if I have no clue about what I am looking at. Well in between NiCd and NiMH it says "SW1". I removed the trace bridge and added a switch hey guess what theres a rectangular hole under the instruction sticker right on the back plate. I moved the sticker and now with a screw driver I can switch between both charging modes. Its almost like SureFire was planning on upgrading its batteries and included this option in early planning but forgot to remove it after figuring out what Stride Gum found out. Longer lasting is bad for business! Well its good for me and my charger doesn't blink in the NiMH mode. I think I'm getting a full charge after 1 1/2 hours on my NiMH 3300maH stick. I took a pic before adding the switch. Its all at work so I never test it for voltage off the charger or runtime I just know I can charge it once every 2 weeks. It helps to run a X80 LA modded to SSC on a GD750 (sigline link #1)
I recently snagged some dead B90s and 8NXs on CPFMP for cheap, and decided to upgrade these B90s as well.
Got these button top cells from all-battery, not sure if I believe the 4500maH claim but the price is right, and I got free shipping at the time.
I'm getting heatshrink tube and kapton tape, to isolate the negative return ribbon from the first 2 cells in series. Now I don't have a tack welder and I've heard soldering to the battery case is a bad thing for the cells so....
My Question to you the community is will the heatshrink be enough to hold the cells in contact with each other and the ribbon to the last cell? Or is there a conductive epoxy out there that will hold it all together better under the heatshrink.
ASEpoxy is not conductive enough.
I considered a conductive sheath heatshrink tube and kapton taping the first 2 cells but the tube is too expensive at 1 1/2" dia.
Thanks,
Brian
Thanks,
Brian
