Can I put a longer clip on my E2e?
JohnfromMD
Maryland
I love my E2e but was wondering if I can put the longer clip on it.(mine has the short version) IF so, where can I buy a long clip?
Thanks,
John from MD /ubbthreads/images/graemlins/help.gif
Just ask any dealer for an E2O clip (same as the clip on the newer M2).
Or call SureFire -- they been known to send them free upon request.
Larry,
Do you just tap out the clip with a drift pin and then tap in the new one?
John from MD
john: slide a piece of paper under the clip (to prevent the clip from scratching the light), then use your thumb to push the clip out. it should come out pretty easily. if it doesn't, set the battery tube of the E2e down a flat surface, then insert the tip of a flat-headed screwdriver into the bend of the clip and push it down /ubbthreads/images/graemlins/smile.gif
