snipinglight
- Joined
- Sep 2, 2006
- Messages
- 168
I plan to run 4 Cree using 8AA's. My question is how do I adjust the Shark converter to feed 3.5V and 700mA into each Cree?
DonShock said:If you hook up your LEDs in series, you don't have to try to balance the voltage across each one. The same current will flow through each. There is a potentiometer on the shark driver. Just hook up your multimeter in series with the LEDs, measuring current, and adjust the pot for 700ma. I usually use the multimeter to make the connection from one LED to another for this measurement, then once you have it adjusted you can replace the meter with the final pice of wire to permanently connect the LEDs.
DonShock said:Not necessarily, 22v is just the max that the Shark is capable of. It will only output as much voltage as is needed to supply the current that you set it to. For example, I have a Shark driving 4 Crees at about 1 amp and the total voltage is a little over 12V, I forget the exact value.
DonShock said:Not sure of the exact design details, but I'm assuming it has a sensing resistor on the board that measures how much current is being supplied and it just raises the voltage until the output current is equal to what you set it to and then stops there. The Cree was recently rerated for 1A, but I was going to do it anyway. It's more fun to push the limits. And so far, I've only toasted one driver and one LED and that was by accident when I wasn't even trying to overdrive anything. I am using the McR-19XR reflectors. They are somewhat of a pain since they aren't self-centering like some of the reflectors for the Luxeon star LEDs are.
