Again... what's the 4 die CREE XLamp MC-E LED? And does this compete with the P7?
well,
if one sees the MC-E as a quad-die, parallel wired multichip-led, it is a direct competitor of the P7,
if one sees it as a 2 parallel of 2 series wired strings, then it is a direct competitor of the LuxV (but with the actual double efficient emitters)
but actually it is
1st: way smaller than the Seoul P7, so nearly every existing focusing device for the XR-E will work good (giving a wider beam of course, as the size of the glowing surface is larger) and,
2nd: is simply perfect when wired in series --> better for the individual led dies than parallel wiring AND (most important) there are tested and proven step-up driver circuits avilable for some time now, while for quad-die parallel there are no good drivers and if there are some made, they are much larger because the higher current needs the parts to be larger.
(PS: and it is made from Cree and not Seoul, which means, no matter what document data marketing dept. posts, it works better.
But that is just my totally unscientific sight of things, found while modding around with P4s and XR-Es, where the P4 always was a reason for granted trouble and disappointment. I still use the Seouls when emitter swapping simply is not possible with a Cree for whatever reason, but the XR-E mods are several steps better)
