Originally posted by icecube on 7-16-07, HERE.
Heylo :>
Glad I got pretty much the right light for my purpose. 3W Luxeon is pretty much good for most of my uses.
Anyways. (this has the 3W luxeon, not the Seoul P4) I sent my first ordered Carribean (since I can't spell that right I'll refer to it as C...) in because the head and body threads were not in spec. Say you have a 10mm threaded hole in a engine block, for example. Someone gives you a 9.8mm bolt to go in there. The result on mine? Occasional flickering and unreliable startup. Happened to peer inside the beautiful lens of the replacement I got. Well, hey...
what's this blob on the Luxeon lens? Kinda like a knot on a board of wood. Stands out.
Doesn't mess up the beam that much, it's out of the hotspot. But it makes you wonder...is Homer Simpson running QC over at Peak?
Also. I used the RCR-123a models at batterystation.com for my daily beaters. Seem to be holding up fine, except the battery outer casing doesn't take much abuse
. I ran it straight until it shut off (gets mighty hot) and it ran for about 45min. I know that the batteries shutdown at 2.00volts for self-protection.
So how about yours?
Heylo :>
So how about yours?
