Welcome Cocco,if you decide to have a pouch made try www.morenylon.com .They are capable of manufacturing whatever design you can imagine.Of course this is not only a shameless plug,but Ardak currently has my Arc 4+ for fitting.That will keep you from sending yours in.
The RifOffs CO-37 fits the ARC4+, ARC LS, Surefire E1e, but not the E1e/KL1. You can buy the CO-37 here.
It has a metal belt clip that will work with or without a belt.
I've been using my Arc4+ with the clip installed, and have found it to clip very nicely to my belt. Being a tough light, it can take the exposure. Faster stow and draw than a case. My clip came set tight enough that loss is highly unlikely. Just a thought.
Welcome to CPF coccolithophorid, and stay a while!
I use the Arc pouch designed for the Arc LSH series. It is a little short, but the velcro still catches the flap, so it works fine. It does not have a clip, but I only need a soft case to protect my Arc4+ while it rattles around in my briefcase or knapsack.
Also, check out these threads for similar discussions:
