Szemhazai
If you are biker you probably have it or had already - small, reliable, and waterproof.
The material in new catey's heads is much softer than in old ones, so the method of dismounting the head is a bit different. You have to put a spike of the knife about 1 mm under the connection of head parts and start pushing. After a few moments, the head will crack. If you made a small spike shaped hole then use screwdriver and leverage it
There is nothing new in the head compared to earlier HL-EL500 . Only the led is screwed to the base not glued (new EL500 are the same as 530 shown here)
I have used SSC P4 - U bin SV0I Uf 3,00-3,25V. Using hot blade you are dismounting and mounting new led. You can put some thermal paste under the slug for better thermal conduction. SSC is a bit lower than Luxeon so u have to grind a bit base of this black holder. Check polarity and glue everything - using cyanide glues will mat the led (vapors will enough to do it - it's silicon only ).
Effects :
Distance about 3m, ISO200, time 1/8s, F 2.8, white balance manual - fluorescent light. Power source fresh charged NiMH cells 1,29V each - so on batteries you can get more :naughty:
