Sway
OK to keep a long story short I got my HotLips from Howard today “Thank you very much kind Sir” so I set apart for the first time taking the switch out of my older Mag C no problems so far then I just had to take the thing a part to get the lamp pedestal out of it then my hand slipped and parts went every where…….#$%&! Lucky that thing didn’t take an arm off or worse…..
M@g Inds. Was of no help with an exploded view.
Once you get up off the floor and clean up the wet spot do any of you have a pic of how this cotton picking thing goes back together?
I’m good with the – neg contact on the bottom and the anchor screw through it then the I have the + pos post back on their little post front and back of the switch and the little white part back in the top half the one you first see when you take the rubber cover off. Where I’m lost at is the order of the little ink pen type spring the very small brass bushing and washer and the other white plastic piece…….
/ubbthreads/images/graemlins/hahaha.gif at me go ahead,
Later
Sway
Later
Sway
