Yes and no; in most climates, heat in the summer is not needed or helpful, and electric heat may cost more than gas, so even if it's not "inefficient", it may still be expensive.There's also the rather strange explanation that claims inefficient lights, such as incan, are as power efficient as LED or fluorescent because if you live in a northern climate the wasted energy (heat) simply displaces the need for gas heating. I haven't entirely wrapped my brain around that one.
There are very few places people live where heating is needed year round. In the continental US, the cooling season runs anywhere from perhaps 2 months in places like the north central states to 12 months in the south. Average is probably somewhere around 4. And the heating season probably averages about the same. Any savings in the colder months are generally offset by increased power usage in the warmer months. Not to mention that with today's well-insulated homes you might actually need to actively cool even if it's 30°F outside if you use enough incandescent lamps. Office buildings and stores have had this problem for years, even with the power savings of fluorescent lamps. Typically you need to either run the A/C or bring in cool air from outdoors until temps drop under 30° to 40° F.There's also the rather strange explanation that claims inefficient lights, such as incan, are as power efficient as LED or fluorescent because if you live in a northern climate the wasted energy (heat) simply displaces the need for gas heating. I haven't entirely wrapped my brain around that one.
Umm, most light bulbs are in the ceiling,
That has more to do with design than the recessed CFL's though.I'm hardly on the side of incans for any consideration and consider residential lighting needs in the grand scheme of things to be a waste of debate. Heating needs, cooling needs, and having living spaces larger than we can afford (but won't admit) are a 1000x more of a problem. Still, it's a practical fact that a couple incan bulbs in lamps in your living room next to where you sit will consume less power than filling rows of recessed lighting with CFL
I'm willing to bet the review didn't consider the cost in change lamp a every 2k hours, versus lamp b every 10k hours.It's true, as long as 1) you are talking about the heating season (in the summer with AC it works against you), and 2) you are considering purely energy use and not cost (gas is not the same as electricity).
wikipedia linked to http://www.usnews.com/articles/busi...-the-end-of-the-light-bulb-as-we-know-it.htmlwikipedia said:Cost
While the purchase price of an integrated CFL is typically 3 to 10 times greater than that of an equivalent incandescent lamp, the extended lifetime and lower energy use will compensate for the higher initial cost.[20] A US article stated "A household that invested $90 in changing 30 fixtures to CFLs would save $440 to $1,500 over the five-year life of the bulbs, depending on your cost of electricity. Look at your utility bill and imagine a 12% discount to estimate the savings.
usnews said:How do I save money, when a CFL costs six times as much as an old-fashioned bulb?
Each cone-shaped spiral CFL costs about $3, compared with 50 cents for a standard bulb. But a CFL uses about 75 percent less energy and lasts five years instead of a few months. A household that invested $90 in changing 30 fixtures to CFLs would save $440 to $1,500 over the five-year life of the bulbs, depending on your cost of electricity. Look at your utility bill and imagine a 12 percent discount to estimate the savings.
Efficiency is not based simply on performance, but as a sum and a derivative of the total cost versus the marginal benefit that came from the product after production.
Building a regular incandescent lamp requires
Metal sleeve
argon gas
Tungsten metal
Vitrite insulation
Glass globe
Not too much stuff, and most of it can be recycled either by reusing, smelting, or absorption.
Now the CFL just the ballast alone is complicated.
plus the hazard like phosphor powder, mercury vapor...plus whatever non RoHS materials used in it...contributes to a HUGE cost to recycle them...heck, I haven't seen a bin around here that advocates recycling them. What I have seen is broken ones in dumpsters that looks like they were shot to sh1ts by a pellet gun.
I've seen too much in dumpster diving trips...
Whats seen...can't be unseen:shrug:
LInk?That's very interesting as a sum of the whole! It was just mentioned that a manufacturing plant in Europe was closed due to some deaths from the mercury that was used to make cfl's. If one looks at the whole cycle from manufacturing to the disposal, cfl's just don't seem to be that great of a deal.
LInk?
I googled it in various ways and found nothing but 'fish' related mercury exposure.
Not saying it's nto true, I'd just like to read the article and couldnt' find it. :shrug:
