Change flashlight "modes"?
Scotsman1886
I picked up an UltraFire with a pressure switch to try on my rifle. It is the model with the multi function light.
Is there a way to change it so it only turns on "bright" and doesnt cycle through all the modes with each press of the switch?
There are many Ultrafire lights which are multi-mode. It will help if you can be very specific as to the model.
My guess is that you have a light which is a P60 host, in which case you can replace the LED drop-in with another that is single mode.
does the head of the light unscrew? If so, is the LED drop- in removeable?
