Here's something I've been wondering. I saw my issue raised in some old threads, but saw no answers to it.
What about charging hi-capacity D cells? I have some 12,000 mAH ones. Fastest charge rate on most chargers is 2000 mA (many are less than that). That's .17C. Isn't this less than ideal for a NiMH? Won't it be somewhat harmful to the cell in the long run? Why don't the charger mfrs make universal chargers that put out 4000 mA or more? Doesn't the slow charge rate make end-of-charge detection problematic on these big cells?
Which leads me to my next thought. I just ordered a c9000 and was thinking I'd rig some leads so I can charge a few D cells with it. I figured I'd set it for 2000 mA. But I read one thread where someone was concerned about excessive heat with this setup and was keeping their c9000 set to 1500 mA. Would it be problematic if I use this unit with D cells at 2000 mA? Since the c9000 was not designed for C or D cells, will its termination algorithm do a decent job with them considering the .17C (or lower) charge rate?
