JeffOYB
I've been doing some research and querying around to see what cheap little light would work for bike commuting and XC trail skiing (mt bike trail riding?).
It seems like the Crees have too small of a hotspot. I got suggestions to make a diffuser to widen the post. I tried a test with scotch tape and kinda got the spot to widen but it weakened also.
In the end I got a MTE SSC P7 5-mode 900-lumen from DX for $40, 18650.
I had started my quest from my "home base" of using Petzl headlamps. I've always liked them but they're kinda weak for road biking. They released a new model this summer the Myo-XP (I think) at 85 lumens. I was impressed. Then I discovered DX! ...Then CPF! : ) I next tried a $17 RC-W4 Cree 3AAA at, like, 170 lumens. I thought it would HAVE to be great---reviewers mentioned "great spill". Then I discovered the limits of a tight spot. It was NO GOOD. So I asked around more and got the tip to the P7.
The P7 so far has proved to be great! ...But I've only tried it a few times. It seems to have just what I need: a 15-foot wide bright area at 20 feet in front of my bike (or skis). (Sure, it probably doesn't have 900 useful lumens, but it does have a wide spot and superbright spill.)
*I NOTE THAT BIKE LIGHTS SEEM BEST JUDGED BY *DEGREE* WIDTH OF THE BEAM. A 15-20 deg beam seems useful. (16-17 if you want to get picky, for the road. 20 for trail.) I don't recall seeing beam-angle mentioned on CPF or in DX reviews.
(I tested a $2 and a $4 DX handlebar mounts. I think the *other* $4 mount would be better--the one with angle adjust. The fixed $4 mount seems frail---I may epoxy rather than rely on the tiny, shallow screw.)
Here are a couple images showing several beamshot comparisons.
This first image-comparison shows, on the left, the RC-W4 plus my Petzl headlamp (I used them together)--it worked only OK/adequate---not great. On the right is the P7 by itself. Looks great!
http://outyourbackdoor.com/images2008/beamshots.bike.side.by.side.jpg
Here's the trail comparison with all 3 lites used as headlamps (stick lights use velcro strap)... Left: Petzl Myo. Center: P7. Right: RC-W4.
http://outyourbackdoor.com/images2008/beamshots.ski.side.jpg
Over Sized images changed to links
