Cheep C monster
paulr
Ingredients: one cheap generic plastic 2C light, one 700 mA KPR118 bulb ($1.29 from RS), three Yuntong CR123's, a sliced down TP roll wrapped with one of those cardboard coffee cup wrappers, taped together with packing tape. Other similar mods have used rubber hose, PVC pipe, or nicely machined nylon sleeves, but I never felt like scouting the hardware store for that stuff, so I did it with free materials that were on hand.
The cardboard stuff is pretty sloppy. It's hard to get it to wrap smoothly, especially the cup holders, which had pre-formed creases. But it does the job. Just to reduce the slop a bit, instead of leaving the three 123 cells loose, I made a "battery stick" by taping the cells with a lengthwise piece of packing tape. Swapped out the PR4 bulb for the KPR118 and viola.
Output is only slightly less than my Streamlight TL3 and the hot spot is roughly the same diameter and color, but the TL3 hotspot is much smoother. Throw should be in more or less the same ballpark. I ran the light for about 2 minutes and the bulb holder and reflector and lens did get warm, but didn't seem in danger of melting. Do I need a longer test? Perhaps slightly worrisome, the spring contact at the tail end of the flashlight also got warm. I could feel this through the plastic as the light was running, but couldn't reach in far enough afterwards to actually touch the spring.
This light should be brighter than most 2xCR123 lights and have more throw because of its bigger reflector. The big reflector makes up for the not-so-precise filament placement of a PR bulb, and the bulbs are pretty cheap compared to the exotic bi-pin bulbs or lamp-reflector assemblies in higher-class flashaholic lights. Changing batteries using the taped "stick" approach is a bit of a chore, but of course you can always make up a spare "stick" in advance.
What we have is a light that's not pocketable but is still fairly compact (much smaller than a 2C Mag), is cheap ($3 host light, $3 in batteries, $1.29 bulb). It's not so great for everyday use but should make an excellent glovebox light (bright, long throw, lithium powered for shelf life and cold weather, reasonable runtime of maybe 90 minutes). This is what I'd put in my car if I didn't already have a PT Surge there.
I'd wanted to do this mod for a while and am glad I finally got around to it.
You can certainly do a cheap 2C this way. But doing it to a 2C M*g makes a thing of beauty that works!
I did something similar to what was a nearly worthless 2D light that had a decent switch and ergos. I use it in the garage to look down into 55 gallon drums.
The 2C Mag is quite large compared with this plastic light. The plastic light is just about 2 cm longer than a 2aa Minimag, though a lot thicker. It's also just a fraction of the weight of a 2C Mag, especially since the lithium batteries are so light, besides taking less glovebox space. It feels almost like there's no batteries inside. I think once you've gone to a fancy relatively expensive light like a 2C Mag, you might as well use a light that was designed for 123's, for example a Dorcy Spyder which is in the same price range, or a Pelican M6 which is just a little bit more.
Hi paulr,
Sounds like a real nice mod /ubbthreads/images/graemlins/thumbsup.gif
I did something like that with a Dorcy FrostBright 2AA. I used a hand file to cut away the AA support ribs in the tube so I could slide 3 123's inside and replaced the factory bulb with a KPR-112 I had to use several small shims between the bulb flange and the reflector to get it in to tight focus. The beam is not to pretty but it makes for a very nice light weight pocket size eye scorcher.
Total cost around 6 bucks /ubbthreads/images/graemlins/wink.gif
Later
Sway
