Clean up that ugly Dorcy 1aaa beam!
pedalinbob
Michigan
i really liked the dorcy 1aaa, ESPECIALLY for $6.
it was good stock, but i thought it was too blue and a bit too ringy. the solution? modify it!
the first thing i did was to figure out how to remove the reflector. i used a 9/32 1/4" drive socket to carefully pound out the reflector and lens. you have to take the head off and do this from the inside--carefully.
next, i sanded off all of the chrome in the reflector. the underlying plastic is black in color. (i may paint it a flat white--mostly for looks)
next, i swapped the stock LED with a nichia 6400mcd. it's beam is just a little blue in the center, and about the same brightness or just a little brighter than stock.
voila! i compared it to my wife's arc aaa (THE standard by which many are judged): same brightness, similar blue center hotspot, larger spill.
now my little dorcy is good enough for even the most devout flashaholic! total cost: about $7!
a little note to dorcy: GREAT job on this light.
however, one huge improvement could be made: leave the reflector unchromed or simply paint it white.
another possible improvement would be to try to get LED's that are a bit less blue.
i cant wait to find more--i intend to get about 10 and give them as gifts.
Bob
nice mod thank you for shareing ill have to try that.i just got back from walmart geting more of em.
I thought they used Nichia LED's to start with?
BTW, try dusting technique on the reflector with glow powder. Should help scatter the artifacts more and then you're left with a nice glow when you turn it off!
