Cold Steel Recon 1 - Review
BR101
Cold Steel Recon 1 Specifications:
Blade Length: 4"
Blade Thickness: 3.5 mm
Overall Length: 9 3/8"
Steel: Japanese Aus 8A Stainless w/ Black Tuff-Ex Finish
Weight: 5.3 oz
Handle: 5 3/8" Long G-10
Pocket Clip: Stainless Pocket / Belt Clip
Today I am reviewing the Cold Steel full size Recon 1 spear-point knife. This is my first Cold Steel knife and after using it the last two weeks I must say I am impressed with their quality, durability and value. At over 9" inches overall length, this knife is big. I will just get that out of the way right away. It may not be the 'best' EDC knife but that's all personal opinion. I carried this knife every day for about two weeks without and problems. If the full-size version is to big don't worry, Cold Steel also makes this knife in two smaller sizes, a Mini and Micro which may fit your EDC system better. Anyhow, onto the review...
http://1.bp.blogspot.com/-iuUEEokWnj8/UJ2Hs4dJ5ZI/AAAAAAAAKzc/RoHiCcIpTEw/s912/20121109_171755.jpg
Starting with the business end, the Cold Steel Recon 1 has a 4" long by 3.5MM thick AUS 8A stainless steel spear-point blade. Out of the box this knife was SHARP! Probably one the sharpest out of the box knife I've reviewed thus far. AUS 8A stainless steel may not hold a edge as long as other superior steels, but the nice thing about AUS 8A is it's fairly easy to service and it takes a razor edge. It also has a good resistance against rust.
http://3.bp.blogspot.com/-GkF365wKc1o/UJ2IAUQPuII/AAAAAAAAKz8/rJisemma6Ms/s912/20121109_171952.jpg
After two weeks of cutting and chopping stuff like tree branches, cardboard boxes, rope, and all sorts of misc stuff. This knife still has a sharp edge, perfect blade centering, and lock up on the knife is rock solid! It has absolutely no side/side, up/down or in/out wiggle. This is attributed to Cold Steels TRI-AD Locking system. The Recon 1 has a reversible thumb stud for right and left hand deployment. The Recon 1 uses bronze phosphor washers so deploying this blade is easy, smooth and fast!
http://1.bp.blogspot.com/-KtZSVredCn8/UJ2GyWkLT2I/AAAAAAAAKxs/Uw8fr5bzZvE/s912/20121109_163524.jpg
http://4.bp.blogspot.com/-h9OpAtBVgQU/UJ2HNsDlEaI/AAAAAAAAKyk/B4Y0slEY9fM/s912/20121109_163755.jpg
One of the best features of the knife is the handle. It’s made out of G-10 with no steel liners. It uses a 6061 aluminum backspacer. The shape fits my hand perfectly, and the texture is outstanding. It has a rough texture for good gripping when cutting in wet conditions, but not rough to the point where it tears up your pocket. Another thing I like about the handle on this knife is there is some jimping. While it's not the best - it's better than nothing. I think if they would have incorporated the jimping into the lock bar to make a full transition from side to side it would be 10x better. Another thing, OD Green and Coyote Tan handle versions would be awesome!
http://1.bp.blogspot.com/-NyuzRuWrqHg/UJ2IJCAJV7I/AAAAAAAAK0E/6gQQRg60fIQ/s912/20121109_172019.jpg
The pocket clip is strong and the knife rides fairly deep in the pocket for being a big knife. This is a left or right TIP UP only knife. I've read of some people saying it was an issue pulling the knife out of their pocket do to the texture of the G10 and the clip being so tight. They said they removed the pocket clip and sanded down the area of the G10 where the pocket clip contacts the handle for easier deployment. I didn't have to do this. It goes in and out of the pocket easy for me.
http://4.bp.blogspot.com/-u1dMj65wvqI/UJ2G5BRtfdI/AAAAAAAAKx4/LSVypdjhGYc/s720/20121109_151408.jpg
Things I Like:
Blade: One of the sharpest out of the box knives I've ever got. Holds a edge, easy servicing and gets razor sharp!
Handle: G10 handles with a good texture for a firm non-slip grasp. Not to mention there are no steel liners on this knife. Don't worry though, it's still a heavy-duty beast of a knife!
Pocket Clip: Sits this huge knife perfectly in the pocket. No moving around and going in and out of pocket is easy.
Value: I feel for the price this is a great knife for someone who does heavy duty cutting task.
Things I Dislike:
Jimping: Just my personal opinion. But I would have liked to seen it transitioned over onto the lock bar.
Colors: OD Green and Coyote Tan handle versions. Again my personal opinion.
Feel free to read more reviews on knives and gear on my website. Also, be sure to follow me on Facebook and Twitter to keep up on reviews, pictures, raffles, and giveaways.
http://www.facebook.com/BladeReviews101
http://twitter.com/BladeReviews101
Thanks,
- Scott
Your images are too large and have been replaced with links Please resize and repost.
See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Thanks Norm
I'll bring this back to the top. Good review, and I'm surprised there are no reply's except mine.
Bill
I just bought one of these, it's lighter than I expected but not too light.
The only two complaints I had with the knife when I opened it were.........
1. The scales are too grippy
2. The clip has too much tension behind it.
Combine them together and it makes it a chore to get out of my pocket.
My remedy.....
1. Take the clip off and carefully bend to reduce some tension but not too much.
2. Use a dremel with sanding disk to smooth out the scale just under the clip contact point.
3. Very lightly hand sand the face of both scales with a fine grit sand paper to remove some of the texture.
After doing these three simple things the Recon now can be pulled from my pocket easily yet is not loose fitting and will not "fall" out. The grip is still very good on it after sanding it down some. The grip is about equal to my DPX HEST 2.0 scale now. Over all it's a nice knife IMO and fit my big hands well.
Thanks for the review.
Jamie
Jamie,
After you carry it and use it awhile the G10 gets alittle smoother. Mine slides in and out of the pocket with ease.
Glad you enjoy the knife though :)
