Combo pouch, Mini-Review
DieselDave
Super Moderator,
FL panhandle
I bought this pouch at Wal-Mart a month ago for $12.99. Academy has it for $16.99. It is located with the flashlights. I cut off the large brand name logo from the pouch, I prefer all black. The pouch can be carried vertically or horizontally as it is in the photos. It has two means of attachment, 1. feed your belt through or 2. It has a Velcro strap. The velcro strap does not seem very secure and you get lots of movement. The Velcro strap can only be used for vertical carry. The preferred vertical carry choice is through the belt. I have been impressed thus far and I wear it all day every day. I have carried it both ways and they both have their pros and cons. I carry a AA Mag + Victorinox Multi-Tool (may (be the largest and heaviest multi-tool on the market) and pen. I have the kroll switch on my AA Mag and it is still about 1” from the bottom of the pouch when fully inserted so I do not get inadvertent activation. The head of the mag sits down in the pouch very snugly. I think the ideal size multi tool for the pouch would be a Wave or similar. My Swiss-Tool kinda takes away the second pen slot. Removal and storage is flawless. Each pouch compartment is reinforced at the insert portion so you don’t get rollover when reinstalling the tool in the pouch. There is room for another pen or ARC AAA. I would use the attached clip if I was going to carry the AAA. It has a molly ring as well as a fastener. I took off my fastener. On a scale of 1-10 for quality I would give it a 7, for design a 8.
Respectfully submitted
DieselDave
Nice.
This is the one I bought...
New Sun Liberty Pouch
The Inova X5T fits essentially perfectly when carried bezel down with a paracord lanyard. I also carry in the pouch...
Fisher Bullet Pen
Leatherman Wave
Blazer Pocket Torch
micro tweezers
3 pieces of write-in-rain paper
small comb
eyedrops/contact lens case (when using)
sewing needle
(sorry about the long link!)
Hi Krept,
That's a nice size pouch (not too big, but large enough to be useful).
Krept,
I like that pouch. Better size, cleaner. I bet I could sew on a closing top AA Mag holster to the thing or step up to the pump and buy the ARC LS2. I don't like carrying anything on the outside where it can scratch or be scratched. Otherwise I like it much better. We need more input!!!
Ok here are links (hopefully they work) to pics I just took. Sorry if they are screwy, I had to sneak out the work camera and take the pics very fast.
Well, so much for posting direct links to the photos (free web host = sucks)
Go here to check out the list of photos.
Here are the explanations. A $1 is used directly behind the pouch as a size reference. In order...
'edc' = my EDC gear. Pouch (when outside). Wallet and Microtech Auto Amphibian.
'empty' = a shot of the pouch when open. at the very bottom of the shot is a pouch incorporated into the back, rear portion of the inside of the pouch. Visible here is the web of elastic. On the other side is another internal pouch. I don't use this one for right now.
'front' = front of the pouch, packed with stuff.
'inside' = in the pouch, gear as I carry it. Fisher space pen is tucked in between the Wave (left of it)and the X5T in the webbing. Lighter is to the right. I don't smoke, but having a pocket torch like this can come in handy (light soldering, need fire, etc.) Directly behind the Wave is a small pair of tweezers with a small lanyard (so it doesn't get lost). [note the shape of the pouch ... tapered so the mouth is larger than the bottom, allowing for quick access of gear. After opening, I kind of have to "put everything back together" to make it into an efficient package. Not a problem, but elastic on the sides would aid with this).
'rear' = rear shot of the pouch showing the attaching mechanism. I would probably replace this with a velcro strap, kinda er... hard to explain, probably like the pouch in the first post? This method of carry works very well, however, and is quick on-quick off of rope or web belts. Might just leave as-is.
"side" = side view. Note the elastic band on hanging off the front. It is too large to act as a rubber band to keep the pouch contents secure against each other. I suppose if you utilize the maximum volume of the pouch, it would work fine but with my stuff, tis too large. Thinking of a mod for this.
"the stuff" = all the junk I carry in the pouch. Note same elastic band on pouch that is mentioned above. left to right, generally... my visene (wearing contacts today) the micro torch, fisher bullet pen, comb, leatherman wave, folded write in rain paper, inova. Not shown is a paperclip (?), needle (aka steel toothpick)
and some aspirin that I keep in the zippered front.
What would I do different? I'd put more elastic webbing where I would need it most. As of now, the lighter kinda just sits in the main pocket because the Wave is using the largest section of webbing. The two smaller sections of webbing on either side of this are too small, enough to accomodate a pen but nothing really of a larger diameter.
Also, would like to have zippers or velcro on the inside pockets. I guarantee if you put coins or something in there, they'll come out if you toss the pouch around.
Would also put some elastic straps on the outside of the pouch to help keep it closed. It really can hold a lot more volume than I really use due to the tapered design. The mouth folds out a lot, which is nice because if I want the lighter, wave, etc. I can just unvelcro the front flap and everything is made available without spilling all over the place.
Yeah, this pouch is pocket-sized, meaning that if you want you can tailor what gear you want to carry in it enough so it will fit in your pocket if you don't like carrying it outside of your pocket. I tried pocket carry for a while but it's so convenient to carry outside and relatively unobtrusive, so I carry it on my belt when going outside.
Am thinking about changing the Inova out with something different. Also the Wave. These two items really add to the relative weight of the pouch, but other than that, it's great.
I looked around a lot on the net for something like this and New Sun Gear made this one which was the closest to what I wanted.
Unfortunately for me, I don't have a sewing machine (yet) so major mods are going to have to wait.
Hope this helps...
Hmm... it's not letting the pics go through (kinda like geocities).
Very cool though that someone set up that site for CPF.
thanks
Anyone know if the "New Sun" pouches are available in the UK (or at least any US sellers that don't charge the earth for shipping)
Thanks
Sorry, but I have to disagree about the New Sun Liberty Pouch - it is one of those items that looks great on paper (screen....?) even seems like it is going to be fine when you pick it up in the shop, is well made w/fine materials, BUT: it just dosen't work!
I tried using it "as is" and found that nothing stayed in it, except for small items in the zipper pouch. OK, so some stuff did stay put, but who want's to leave a trail??
And basically, there is not all that much room in the pouch compaired to it's outside dimensions - I think they tried to build too much into it and ended up with an overly constructed item.
Anyway, I tried adding a strap and velcro closure on the outside keep stuff in place, but the net result was even less internal space.
The wider opening top seems to be the problem: too much cloth when it is closed, too easy for stuff to fall out when it is opened.
My .02, anyway.
I have and used both the New Sun Liberty pouch and the New Sun handyman pouch. I like the handyman pouch better, even if it's slightly smaller. I didn't like the tapered opening of the main pocket, it tended to fall open too much. It could hold more gear though. The handyman pouch is just the right size and can hold quite a bit without becoming too bulky. Currently(this always changes) the pouch contains a SAK Cybertool 41, SureFire E1e, Fisher retractable space pen, Leatherman Squirt, 2 spare CR123A batts, 3 spare AA batts(for LGI carried seperately), and sometimes a CMG 04. I like this set up, but I am still looking for the ideal pouch.
I am currently trying to create my own design in an EDC pouch for the belt. It will be made of neoprene with a clasp closure, no velcro. It should be large enough to fit a multitool, small light(E1ew/KL1,ArcLSw/123A body), spare batts and space pen, maybe more. I have the next few days off, so I'll try to work on this.
Hey Sonic. Do you have a link to the New Sun handyman pouch? I did a google search for it but didn't find it. I'd like to see what it looks like. Thanks.
Nice. that liberty pouch was the smallest I could find. Hey Maury, there are certainly things like you mention that can be changed on the pouch, that's why I'm looking hard at what mods to do. I hope other people post re: pouches like this to give others an idea what's out there.
--> Edited. Just found the handyman pouch on brigadequartermaster.com - same place I bought the other pouch from
