Compact Multiple Cell AA
AnthonyMcEwen2014
Eastsussex, UK
I need some advice for the above, I will also be clamping it to a bike, its replacing a Led Lenser P7 ( :-\ Meh light )
It MUST be able to sustain a 400 (Ideally more) lumen output without steping down.
Currently considering a EA4 (lockout has issues thouge)
Here is the list.
==================Flashlight Recommendation Checklist================
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Up to $100. (£65 from a UK dealer)
3) Format:
____I want a flashlight (hand held/self contained).
____I want a mounted light (typically for a bicycle or vehicle)
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
(I will also except super cool alien tech that puts out more light than the sun but in a keychian size)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
I WOULD LIKE A SUPER TURBO OF 700+ LUMENS!, not critical but a highly wanted feature.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Any size switch will do! (No extreme UI with a hindered modes and sublevels!!!!!!! Anything more complicated than the EA4 and its no go, I need to be able To change modes without doing a problem solving test at the same time.
Thank you in advance!!!!
Re: Suggestions for COMPACT Muticell AA flashlight.
No question for me: The D40A, probably in NW white. 4xAA, compact, good quality, 980 ANSI lumens, good switch, great tint, nice beam, good throw. For me this is as good as it gets for a 4xAA. Edit: This is not a bike light. You might probably get a bike light then.
+1... D40A. - Moonlight mode
http://www.candlepowerforums.com/vb...e-EA4-Ballooned-Melted-switch-Repair-Write-Up
After reading this, and seeing both the silly customer after care (or lack of) from Nitecore, the EA4 or any other Nitecore light has been scrubbed as a candidate, I understand the odd issue in even the best most high end lights, but when a manufacture responds like that and won't make amends on what is at the end of the day not a cheap (although not expensive) item I won't be doing business with them, may sound harsh but I expect more for my money, I can understand even the best make mistakes but normaly they rectify issues.
As for the advice on the D40A thanks I'll look it up, it dosent need to be a bike light, I will also be using it for other uses, just going to furfill that role temporary + as a back up.
Thanks and sincerely
Anthony.
TELL ME WERE TO BUY IT IT!!!! I WANT IT NOM NOM NOM!!!!
OMG saw selfbuilts reviwe...LOVE THE INTERFACE, looks like what I'm after, tell me were can I spend the money :-D
Looks so good! But can't find a reliable dealer (uk preferred I HATE customs!)
Re: TELL ME WERE TO BUY IT IT!!!! I WANT IT NOM NOM NOM!!!!
Another possibility is the Jetbeam SRA40. If the EA4 is out, then this looks like it would be a good choice. Personally, I don't like the SWM D40A because I don't like battery carriers.
Thanks, already ordered though, I personly dont mind rather way for battery carriers.
Thzx anyways.
