Compatibility KL7
aingel2k1
Hello, does anyone "know" if a surefire KL7 head will fit on a standard 6P type body??
Thank you for your help in advance...!!
The KL7 requires the larger diameter body of the 8AX/8NX. Required voltage for the KL7 is 3.6-4.2 volts, or as high as you can charge the battery pack, so voltage would not be a problem is you could find an adapter for the 6P to fit the head size and threads of the KL7 head.
Bill
Got it , Thanks Guys... does it match up with the larger size SF as in "M3", or M4's??
The 8-Series bezel threads are not shared by any other models. The KT5 TurboHead Kit has a special adapter collar so that a standard KT TurboHead can be used.
The 8AX, 8NX & L7 have the same bezel diameter as the M2 so share BeamFilters.
