Computer help,,update failed with code
2000xlt
Ok went to do an "important" update which failed several times with code "643" update is "KB2742595 and in the error with 643 it says "Security update for Microsoft .NET framework 4 on XP, Server 2003, Vista Windows 7 server 2008 x86 (KB2742595" Any ideas MSI error or corruption? Thanks!!
That error can appear whenever the MSI code has been corrupted, no matter whether .NET 4 or not. or, because the MSI installer is earlier than version 3.1.
The new MSI installer is here:
www.microsoft.com/en-us/download/details.aspx?id=8483
error 643 is identified here:
https://answers.microsoft.com/en-us...b2742595/c58de776-cf12-4148-b835-f0585e6e6b74
There are some sites that offer an MSI installer fix, but if your version is older than 3.1, you need to upgrade anyway. Run a search on MSI installer.
.NET version 4 is generally used for network administration, or possibly by some device connection such as Nokia Suite. It also slows down a computer.
so when the new MSI is installed does replace the old or do i have to uninstall the old first?
