idleprocess
I recently obtained a bicycle and with the onset of fall, it's getting dark during typical riding times.
A friend uses the Fenix BT20. While it produces a bright, automobile-friendly beam that's great for road biking, its area of illumination and light to the sides leaves a bit to be desired when transitioning between lit/unlit areas and on trails.
I'm considering a custom light with 4x XP-G triples. Two will be collimated with 24° narrow optics and the other two will have 43.6° X 23.3° elliptical optics. The idea is to provide a wider spread of light nearby for riding on trails and unlit streets while also sending light forward to see beyond this immediate pool.
I'm expecting to wire up all the modules in parallel and use resistors to control current. Power will be in the form of a 9.6V NiMH pack. I will use a short length of 2"x1"x0.125" aluminum U-channel (at least 6", mounted horizontally to the bars) to house the entire affair with a polycarbonate window.
Using Excel to do some hasty extrapolations of the output and forward voltage curves based on current, I derived the following with likely drive levels:
If and Sum Vf are per-module current and forward voltages
Array P and Array Lm are power and spec-sheet lumens for the entire device
V_Ohd is simplistic anticipated voltage overhead for the array verses the battery pack
Run is anticipated runtime assuming flat pack voltage and uniform amp-hours, based on 2000mAH cells
Fudge-Lm Multiplies lumens by 75% to account for heat, optics, etc
Fudge-Run Multiplies runtime by 75% to account for pack voltage drop, capacity loss at higher discharge, etc
Looks like 700mA drive level is iffy and I'm simply not going to be able to drive the array at 1.5A with a 9.6V pack. Of course, I don't account for thermal effects on forward voltage and surely will not direct-drive anything. Otherwise, 150/350/700mA drive levels will provide some OK output distinctions.
My challenge is fine-tuning the optics. Angling the entire assembly down by about 16° at a height of 36" will make the eliptical beam illuminate from 5 to 35 feet. Angling the narrow optics up about 4° (a ~0.60" shim) will allow the narrow optic beam will intersect the ground slightly further out and proceed to infinity on the upper edge. I can sort of imagine what this will look like, but lack the geometry skill to project it in a drawing, can't really tell how the light will be distributed, and I'm not sure how effective it will be as a headlight. I expect that the foreground will be much brighter the distance in spite of my efforts to try to throw some more light forward. Intensity is clearly never going to equal the BT20's hotspot, which in my mind is acceptable. I was hoping to introduce some vertical cutoff as a courtesy to automobiles on the road, but since the beams aren't as neatly horizontal as 2D projections suggest, should I rethink the geometry and angle up? Perhaps any LED's dedicated to closer illumination should be driven at a lower level? Look at other optical solutions? Rethink the array components?
Appreciate any feedback.
Code:
If | Sum Vf | Array P | Array Lm | V_Ohd | Run | Fudge-Lm | Fudge-Run
0.10 | 8.31 | 3.33 | 358.28 | 1.29 | 300 | 268.71 | 225
0.35 | 8.95 | 12.53 | 1408.56 | 0.65 | 86 | 1056.42 | 65
0.70 | 9.67 | 27.08 | 2666.21 | -0.07 | 43 | 1999.65 | 32
1.50 | 10.52 | 63.12 | 4608.87 | -0.92 | 20 | 3456.65 | 15
