greg_in_canada
(This is not a jab at Vista.)
I fixed a laptop for a friend of my wife. Someone had stepped on the keyboard and bent it and parts below it. The shroud surrounding the fan was bent and the fan couldn't rotate. So I unbent it as best as I could and then the fan spun freely. After a little testing I put it back together and it seemed fine then started scraping. I assume it was because the laptop heated up and the fan tried to speed up (perhaps lifting it on it's bearings).
So I unbent it some more and now I'm testing it again. I'm trying to find a program that is built into Vista Premium that uses a lot of CPU power so that the fan will speed up. Right now I'm running iTunes with the full screen visualizer turned on with no effect (on speeding it up).
Is there any other built in program I could try? (I do have it plugged into the wall so the CPU is running at full speed, not battery speed.) I don't really want to hook it up to the internet and download stuff so I'm hoping for something that is built-in.
Thanks - Greg
Thanks - Greg
