coyote
Re: JIl DD CR2 lights
here's my old info (from july 2006) on the Jil DD
hope it helps:
JIL CR2 DD UP
LED is direct driven from one CR2 Lithium battery
Aluminum Reflector
UCL Lens
Silicone O-ring
CNC machined aircraft grade aluminum (6061)
Dimension : 18mm(D) × 51mm(L) - (Head : 20mm)
Weight : 34g / 1.2 oz (including battery)
Type III Hard anodizing
Run Time : Up to 20 hours
50% brightness after 10 hours
Also on RCR2 for MUCH brighter but shorter run time of 12 minutes at 80 lumens (approx)
Switch : Twist type
Water resistant
Gold-plated PCB
Jil Maker: Hunsu Park of Seoul, Korea
Distributor: eTendue, aka:Woon-Hyeung Cho aka: “Warren” ([email protected])
hope it helps:
JIL CR2 DD UP
Aluminum Reflector
UCL Lens
Silicone O-ring
Switch : Twist type
Water resistant
Gold-plated PCB
