blasterman
- Joined
- Jul 17, 2008
- Messages
- 1,802
The reduced frustration of LEDs on stars is definitely worth any extra expense
LukeA has a point. I can work with bare Cree or K2 emitters, but stars are certainly much easier to deal with...just more expensive. This is why you buy a couple first and get used to soldering. If you just can't deal with bare emitters, then obviously you have to spend the extra coupla bucks for stars.
I am now putting together my 3rd light driven just off a full wave bridge rectifier
Question on this (although I should have read prior threads). Negating the rectifier circuit for a moment, do you wire the 34 (or so) LEDs in one series with AC, or are they split x 2 (RMS)? I have a box of XR-Cs doing nothing and want to try this.
Yes those XR-Es would be super easy to use compared to my first choice. They even go to 107lm on the cooler colors at 350mA.
As per mentioned above, you want to avoid cool-white LEDs because you will seriously hate yourself when you see how cool the room light turns out to be. I prefer warm-white / neutral white alternating, while my brother prefers neutral white. I think part of my reason for not liking straight neutral white is they tend to vary a lot in terms of tint. Alternating them with warm-white evens things out.
I have power LEDs ranging from older 30/40 Lumen Crees to 400lumen Bridgelux, and the leap from 30-40lumen to 80-90lumen is HUGE when it comes to interior lighting. Nothing against Rebels, but you want AT LEAST XR-Es for this (or the newer Rebels). This cuts the number of LEDs you need to use ($$$) in half.
As a result you might feel slightly dizzy if you use too much LEDs in one area.
:thinking:
While bare LEDs on the ceiling are very specular in nature, multiple LEDs spaced half a foor apart or so aren't hard to live with. Plus, GSX said he's going to mount the light track near the side walls, which will produce a large amount of diffuse, wall reflected light in addition to the direct light on the ceiling. This is also why you build one light strip first and see how it looks. Personally my guess is it will look pretty cool, and I'm an ambient light kinda guy.
As far as I am aware of, MCE's are better used in such places like indoor lighting because the emitters are held closer together
MCEs have the benefit of tighter lighting density vs four LEDs, but don't look aethestically better than single LEDs, or have a functional advantage. They can also be more expensive and less efficient than four P4s.
Again, I go back to my Bridgelux which have more array emitters and a larger emission area than MCEs, and they are just as obnoxious when directly viewed as R2s. Bare, warm white P4s driven normally at about 80lumens are about the upper end (IMHO) before LEDs really get irritating to view directly. 150 lumen K2's would be blinding dead on, but tolerable if moved closer to the side walls.
