Current draw discrepancies
Billson
Philippines
I've read a lot of posts describing current draw of lights in BST. I'm wondering why some leds being powered at 700ma are drawing more than an amp from the battery. What causes this?
Or maybe they use a step-up converter, which boosts the voltage from - for example - 3V to 3.7V, and because of this, it requires a higher current to drive the LED at 700mA. So the LED is driven at 700mA, but the converter draws (for example) 1000mA from the batt. Correct me if I'm wrong.
That one is using a step-up converter, because a singe CR123A cell will provide only 3V, and the LuxeonIII LED requires more (around 3.5V).
So there is a converter circuit, which boosts the voltage from 3V to 3.5V, and provides 670mA (constant) current to the LED. But the converter has to draw more current in order to achieve this voltage boost, that's why it's drawing 1.4A from the batt.
Hi Billson,
And if that still doesn't make sense, consider this:
Voltage step-up circuits basically suck extra current from the source (battery) and convert that current into extra output voltage.
So if you have an LED that needs 3.5v and you want to run it at 700ma, but your battery only supplies 3v, then you can "steal" extra current from the battery and convert it into extra output voltage to hit your 3.5v goal.
So, in the thread you mention, that extra (1.4A - 670ma) = 730ma of current coming out of the battery is being turned into extra voltage to power the Luxeon.
pb
