offroadcmpr
I don't remember much about my electricity, so I need some clarification. so if you put two batteries in series the volts doubles, while the amps remains the same?
if you put two batteries in parallel, the voltage remains the same, while the amperage doubles?
I guess I am just looking at the battery comparisons and I am trying to figure out what a 1/2 amp load or a 2 amp load means. so if a AA alkaline is rated at doing well at 1 amp, adding another AA in series makes the voltage go up to around 3 volts, but each battery is still drawing 1 amp each? so to relieve the pressure off a battery, you would want to put them in parallel so they would each draw 1/2 amps, but have only 1.5 volts?
sorry if this has been said before or if it doesn't make much sense.
