lightseeker2009
- Joined
- Jul 29, 2009
- Messages
- 681
I've received my Osram Crosser 3-LED spotlight yesterday. When comparing its output to my Fenix TA21 it is a little brighter so I would put its lumen rating at between 225 and 280 lumens. More than enough what I will use this light with.
The only thing that dissappoint me about this light is the batteries it uses. D-cells.
I dont have a problem with D-Cells but I thought this light will operate with a Lead-acid like all the other spotlights, including other LED spotlights I own. So I had to buy Alkalines just to test it. I want to get D-size NIMH's for it but I've spotted a potential problem.
On this light even on the positive tab there is a spring. That spring is bigger than the positive tab of a battery. The D-cells I've bought works as there is metal from the possitive tab to almost at the sides of the battery. But looking at NIMH D-cells I dont see this metal. This means the rechargeble batteries won't make contact at all.
Have anyone had a problem like this before? How did you fix it?
I only paid something like $4.00 for the set of 4 D-cells so I could continue to use them but I prefer rechargebles as I dont like using throw away batteries.
I've been looking at Titanium 12000MAH's how are they? Could they hold a charge for lets say 3 months?
