Dang it!! PT Surge won't work---
Larry in Bend
Bend, OR
Dang it!! PT Surge won\'t work---
Got a PT Surge from TTS yesterday and it won't light up. I re-installed the batteries about six times - nothing. I don't have a spare bulb to try - Any ideas before I send it to Princeton Tec? Or should I send it to TTS? Thanks for any help.
Re: Dang it!! PT Surge won\'t work---
The switch mechanism is located only on one side of the battery/bulb assembly. Make sure it's facing in the same direction as the toggle switch on the outside of the flashlight as it can be put in backwards.
In addition, even when reinstalling battery pack correctly you must make sure switch engages properly. Experiment with different switch positions be fore reinstalling pack.
Brightnorm
One of my Surges bit the dust. The internal switch mechanism on the battery pack ceased functioning. This happened on the original bulb for the light.
I received my Surge from Brightguy about 6 months ago; it was DOA, the switch didn't work. BG informed me that this light was a "new" one after PT had"fixed" a switch anomoly. I promptly received a replacement from BG, good service.
The light should work OUTSIDE the tube. Just depress the little "button" on the top side of the battery assembly.
Of course, you may have a bum bulb.
It should also work with only four batteries loaded on one side.
Do what JohnK said above. If it lights, then do what d'mo and brightnorm said.
Check the bulb with an ohmmeter or close visual inspection, if you can.
I just received 2 surges last week and both work fine. Hope you get yours working.
Larry send it back to me I'll have one sent out in the morning. What color was it.
Larry never mind I found the order and it will go out via UPS today. Send the other back at your convenience.
Now thats what I call great service. I just received 2 from TTS just last week and a E2e-HA about 2 months ago. Nothing but great service.
Bill
Thanks for all of your responses and the good ideas, I still can't make it light up. - THANKS TTS for your great service - I'll ship this one to you ASAP!!
