ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the DBS V2 DI Cree XR-E WH R2 from Dereelight.
More information at CPFMP Thread
Actualy I received 2 DBS V2 DI Cree XR-E WH R2's. Both lights have the SMO Reflector.
Fron Dereelights website.
Cree XR-E Q5 emitter
Driver choose from: 1S, 2SD, 3SD or DI, 1SM-1 module can handle 2xCR123A
Shut down at 2.7V to protect lithium battery from over-discharging
Limited reverse protection for 5 seconds
Upgradeable
Forward clicky
Smooth reflector, OP optional
Type III hard anodized finish
Using 1x18650, 1x17670 or 1x168a
Dimensions: 158mm(Length)x 48mm(Head)x 27mm(housing)
Material: Constructed of aircraft grade aluminum
Waterproof
Weight: 185-gram weight
Glass: Toughened ultra clear glass lens with double face AR coating
GITD switch cover
Removable clip, Removable anti-rolling ring
Color: Black
Package: Giftbox
Accessories: Spare rubbercap(black), Extra O-ring
The fits is excellent.
The Type III Hard Anodize Black is excellent.
My inital impression's of the Cree XR-E WH R2 beam is that I like the tint of the Cree XR-E WC Q5 a lot more. The tint of the WH R2 is on the yellow and slight green on the other beam. The slight green tint has a higher lux reading. The lux reading is about the same as the WC Q5.
The other thing I noticed was the DBS V2 uses a spring on the tailcap. the DBS V1 did not have the spring.
Using the UI is easy to figure out.
I ordered 2 DBS V2 DI Cree XR-E WH R2 and 1 Dereelight CL1H V3.0 DI Cree WH R2
Left, DBS V2 DI Cree XR-E WH R2 . Right, DBS V1 XRE-E Q5 with 3 Way Module SMO
These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected 18650.
1. DBS V2 DI Cree XR-E WH R2 SMO 18650 - 20,121 lux @ 1 meter
2. DBS V2 DI Cree XR-E WH R2 SMO 18650 - 19,152 lux @ 1 meter
DBS V1 XRE-E Q5 with 3 Way Module SMO 18650 - 20,767 lux @ 1 meter
1. DBS V2 DI Cree XR-E WH R2 SMO 18650 @ 83"
2. DBS V2 DI Cree XR-E WH R2 SMO 18650 @ 83"
DBS XRE-E Q5 with 3 Way Module SMO 18650 @ 83"
Left, 1. DBS V2 DI Cree XR-E WH R2 SMO 18650. Right, 2. DBS V2 DI Cree XR-E WH R2 SMO 18650 @ 83"
Left, 1. DBS V2 DI Cree XR-E WH R2 SMO 18650. Right, 2. DBS V2 DI Cree XR-E WH R2 SMO 18650 @ 83 Stepped down exposure
Left, 2. DBS V2 DI Cree XR-E WH R2 SMO 18650. Right, DBS V1 XRE-E Q5 with 3 Way Module SMO 18650 @ 83"
Left, 1. DBS V2 DI Cree XR-E WH R2 SMO 18650. Right, DBS V1 XRE-E Q5 with 3 Way Module SMO 18650 @ 83" Stepped down exposure
In thse next 2 shots that were seen above. The lights on the left are the 1 & 2 DBS V2 DI Cree XR-E WH R2 SMO 18650. The tint looks closet to what it looks in real life.
Upgradeable
Forward clicky
Waterproof
GITD switch cover
Color: Black
Package: Giftbox
