Sorry for the bad english.
Recently due to a flashlight with a defect (high parasitic discharge) it seems that I have lost two Sanyo NCR18650GA batteries.
The first long time ago I found it empty (the light did not come on) I thought that perhaps the light had remained on or that the battery was defective.
I recharged it and some in time 20 or 30 days this battery it emptied again, in an Xtar VC4 it did not charge, it was seen as: Ni-MH and the charger hand was on 1 V (I don't remember now if the VC4 said 0V or 1V) maybe I tried to recharge it even with a another charger - however this battery has been disposed of.
Later, with an identical battery the same happened, I also tried to measure it with my multimeter (perhaps unreliable) and I saw 1 V.
In VC4 I had the same situation (low voltage, seen as: Ni-Mh, no recharging) I also tried to insert also it in a VP2 but the charger indicator light always remained green without any charge.
I left this battery in the corner for many days waiting to dispose of away.
Today I took it to dispose of it in the appropriate containers but before I inserted it for a moment in the VP2, it immediately went into charge - when the charge started i saw that the voltage was 2.54 V
Charged in VP2 at 0.25 A the voltage in a few moments increased from 2.5 to 2.8 V (too quickly it seems to me ..)
As I write this post the voltage reached 3.35 V (I increased the charge speed to 0.5A)
Inserted for a moment the battery in a flashlight everything seems to work..
This battery may have suffered from too low voltage for an extended period, I don't know if I can trust it.
In the next few days I see if it keeps charging, I still wonder if it can be used safely in powerful lights or if it is better not to consider it a reliable battery anymore.
