deleted
Re: Regulated Headlight for rechargeables ->pix
Nice job slick. What kind of runtime do you think you would get using 2 lithium AA's? Do you think this mod would hold up to a continuous burn of the batteries? I have a princeton tec headlamp I've considered a similar mod on.
Good job, Slick! /ubbthreads/images/graemlins/thumbsup.gif
I'm currently modding a P-Tec Solo for use as a bicycle helmet light. When I'm done, it will have 4 NiMH AA cells in a remote battery case, an XPR-103 bulb and will be voltage regulated by a LM2621 evaluation board that will be fitted inside the original battery chamber. Should be good for attracting the attention of inattentive drivers. /ubbthreads/images/graemlins/thumbsup.gif
Dan
[EDIT] Correct me if I'm wrong but I was under the impression that this version of the MicroPuck was a boost convertor and not a boost regulator. /ubbthreads/images/graemlins/confused.gif
Great light, Slick.
I had been wanting to see some of your mods but it didn't occur to me until last week to look at the sticky.
I really enjoyed the detailed presentation.
Slick,
Two things:
1) lux readings?
2) would ya build one for the ol' Bulkster?
I'll trade you back one of my MPs for the one you'll use to build it...
Great job, Slick! My solution to using an LS for a headlamp, was to buy an Arc LS headlamp mod from Silviron. I got the 4AA series/parallel version for doubled runtimes (14 hours w/lithium AAs).
Given my total lack of shop skills, and almost total lack of tools, it was the easiest way for me to go. Since I am sitting at my computer most of the time, it is way too bright. So I use something alot dimmer, like the Solo with Matrix module.
Nice mod, been wondering if it's possible to safely run an LS in a plastic body.
Seems like you've proven that as long as there is a chunk of Aluminum in there somewhere it's alright.
-YC
