Deployed Belt Carry EDC
dss_777
Weird. My reply is before the posted question... well, here it is:
With the exception of the requested lumen output, sounds like you're asking for the Surefire E1B backup. The E1B is listed at 110 lumens, but they're Surefire lumens, so that might work out OK. Certainly fits all your other criteria.
"Go with a proven performer."
Hi all,
I'm currently deployed in afghanistan and I'm looking for a small (1x123) light that I can comfortably carry on my belt at all times - needs to have a clip that i can put on a 1.5" wide belt. I have a Surefire M3LTS, U2 and G2X Pro that I use often when I plan on being out in the dark, but I want something that I can just have on my belt at all times. Below are my notes from the sticky at the top of the forum. Basically - I don't care how much it costs (tempted to just buy a McGizmo PD-S like I used to have...but I'd prefer something with a newer LED/brighter if possible), want 150-200 lumens with a spot, 1x123 primary, clips on a 1.5" belt, super durable. More details in the following.
Thanks in advance for any help you guys can provide.
S/F,
Kyle
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__X_I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
_X__Less than $300.
____I have no limit.
_X__I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
_X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
_X__Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
_X__I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
_X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
_X__I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
_X__30-50 yards/meters (I have a big backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
_X__30-60 minutes (I have plenty of batteries just ready to be changed)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
_X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
_X__I want a forward clicky (Helpful for momentary activation and signaling).
_X__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
_X__I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
_X__A simple on-off with only one output level is fine for me.
_X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
_X__I want multiple light levels. (Some lights have 5-16 light levels.)
_NO_I want a programmable light.
_NO_I want a selector ring.
_NO_I want a strobe mode. (Blinks to show location.)
_NO_I want SOS mode.
_NO_I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
_X__Plastic/composite body (this may limit your choices significantly).
_X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
_X__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
_NO_“Hybrid” light (bright incandescent combined with long running LEDs)
_X__Pocket/belt clip
_NO_Holster
_NO_Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Off of the top of my head I would say that the HDS Rotary would fit your needs the best. It will tail stand (I believe), has 200 lumens, I believe you can get a clip for it (not sure though...), uses one CR123 battery, is incredibly tough, lets you choose the brightness by rotating the ring or by double clicking to go to preset brightness levels, about 200$. It's an incredibly tough light and would be able to survive combat conditions.
Another light off the top of my head would be the Armytek Predator, if you were willing to use two CR123's. Only thing is it doesn't tailstand and requires a little bit of programming at first to set it up to fit your needs. That would be another light that I think would be fit for your AO. Very tough, dependable, bright, and simple once you program it. Out of the two I have a feeling that you will go for the the HDS though.
