WadeF
This light rocks! For $109, which included $15 EMS express shipping, I got the following:
-Dereelight CL1H 2.0 w/ Cree Q2 bin 2 Stage Module (low / high) w/ OP reflector
-Optional Cree Q2 bin 5 stage module (low, medium, high, strobe, SOS) w/ OP reflectr
-Spare smooth reflctor that can be swapped with either module's OP reflector
-Spare o-rings, GITD tailcap (default installed on the light), black tailcap, and a black low profile tailcap which allows the light to tailstand.
-Cool box that nicely holds and protects the spare components.
With the OP reflector installed the HIGH on this light is comparable to my Malkoff M60 (P60) Cree Q2 that I have in a Surefire G2. Both are Cree Q2 running at 1000ma so they should be basically the same.
With the smooth reflector it has a ringy beam, but the throw increases noticeably.
With the 2-stage module installed going from LOW to HIGH is as simple as twisting the head.
This light features a momentary forward clicky, like a maglite. With the 2-stage module you can signal (flash) in either HIGH or LOW. A full press will click and keep the light on.
With the 5-stage module a momentary forward press will turn on the light, but successive releases and presses, without clicking, will step you through the different modes, low, medium, high, strobe (very fast strobe), and SOS (faster than the SOS on Fenix). Once the desired mode is found a full press to CLICK will hold that mode. Wen the light is turned off, and then turned back on, it will return the the last mode selected. So if you have it set to strobe, turn it off, and turn it on the next day, it will still be in strobe.
With the 2-stage you can use 1x18650 protected or non-protected, 168a (which I'm not familiar with), 2xCR123A, or 2XRCR123. If usin a protected 18650 with a nipple you should remove he screw on the inside tailcap. With the 2-stage the + (positive) on the battery goes to the tailcap.
Dereelight claims 18650's offer the best performance. Over 20 hours on low!
With the 5-stage you can only use 18650 or 168a batteries and the + (positive) goes towards the head.
You should also check out Fastcar's review:
http://www.candlepowerforums.com/vb/showthread.php?t=172187
and here is Alan from Dereelight's topic which has direct ordering information, specs, etc:
http://www.cpfmarketplace.com/mp/showthread.php?t=166478
Tonight I took my kids for a 5 mile stroller ride in their jogging stroller. The Dereelight rode clipped to my front left pocket and I never felt it the entire trip! I went out with the 5 stage module and the OP reflector. I'm a sucker for modes.
I kept it in HIGH most of the time.
Before the stroller ride I had the kids at the playground and towards the end it got dark. Nature called and I had to enter a completly dark porta-potty.
With the Dereelight I was able to clip it to the outside of my pocket and it illuminated the target hole nicely. Too nicely! :sick2: However, it made for a handy hands free flashlight experience. Sorry if that was to graphic or gross for anyone, just found it to be a practical real word use.
So anyway, this light feels and looks great. For it's size it's not overly heavy, but it's solid, with a nice HA finish. It feels comfortable and secure in the hand.
I'll be looking forward to future modules. Hopefully we'll see a Q5 module, or someday R-bin modules.
Now for some pictures! I'll try to get some beam shots soon, I took these during daylight hours:
Next time I hand model I'll have to remember to trim my nails.
You may click on the images to view them in hi-res.
Again, I'll try to get some beam shots up.
