As long as the head tightens down without a big gap between the head and body, you can use aluminum foil to help the malkoff module make perfect contact. I do this on surefire bodies too just for good measure, as an added benefit it helps heat sinking. If you can't get the head tightened down then I guess it just won't fit a CL1h
