Dereelight EZ900 cells, LVC?
kwak
Athens, Greece
Hi guys,
I have a Dereelight XR-E R2 EZ900 (Half way down the page) on it's way with the Aspherical lens and 18650 extension tube, and am looking to buy a few more cells, but have a few questions please.
1/ Does this light have a LVC (Low Voltage Cut-off)?
2/ If so then does it work with 2 x 18650 cells or only when using 1 x 18650 cell?
3/ Again if it has a LVC at what voltage does it cut in?
3/ How spacious is the battery tube?
i.e. is there likely to be a problem getting say 3100mAh protected cells to fit?
Cheers
Mark
I have the deree aspherical ez900 and i run it on two 16340s with no problem. not sure about low cut off voltage. I have a fenix tk15 too and i saw a review on it saying 3100 mah cells will fit that light so i compared the battery tubes of the both light and the deree is more spacious so you will have not problems with that.
From what I can tell from flashlightconnecton the operating voltage is 4 to 9vdc. So a single 18650 won't work properly. I run AW 2900's with room to spare.
