Diffuser / reflector for garden lantern
  • Thread starter Thread starter mjpg
  • Start date Start date
M
mjpg
Guest
I'm making some lanterns for the garden. I want to use maybe three 5mm white LEDs per lantern. The ones I have are narrow beam (+/-10deg) ultrabrights. I'd like to disperse the beam. I have tried the following:
* Abrading/sanding the lens of the LED package
* Mounting in a hole drilled in Perspex
* Pointing the beam at an oblique translucent surface (actually a plastic milk carton)
* Pointing at a ball-bearing
* shining through a plastic 'crystal' bead.
None of these were great although the milk carton seemed best.
Does anyone have a suggestion on how I might get a more diffuse light - or should I source different LEDs?
Thanks
