Dilema
madecov
Houston, Texas
Since Surefire can not or will not FIX the B90 problem I need to find a good rechargeable light for on duty.
I don't care for the streamlight Stinger.
I am considering getting a SF D3, then I would get the Lithium Ion batteries from Copia and have a rechargeable light at 105 lumens.
Question is, can these battery's power a P91 ? I know I would get reduced run times. But will I get the 200 lumens ?
Madecov, 150b that fit D3 has 1000ma that might be too weak to drive P91 in reasonable runtime unless you accept 10 min runtime and yellower light. In order to drive P91, 168b (1400ma) would do well but it won't fix D3 unless you add an A19 extension tube. The bat (168A) that comes with your M90 will be more than adequate to drive P91 but again, P91 doesn't fit M90 bezel.
Alan
I dislike he focusable lights, The Surefire line has a better more white light.
I had a Stinger several years ago and found it lacking in output.
