I've found a
Dimmer for D-cell lights in the German Globetrotter shop (sorry it is in German).
Sounds very simple. The dimmer is a disc (33mm diameter, 5mm thick), which is placed between battery and tailcap. If you switch the lamp on and of very fast, you can toggle between different brightness settings.
Would be ideal for MAG LED mods.
Unfortunately the maximum rated current is only 1 Amp.
