twhitehouse
- Joined
- Aug 27, 2010
- Messages
- 16
Am I correct in the following?
A diode from Radioshack has a maximum Vf of 0.8, capable of handling 1A.
A Cree XP-E has a maximum Vf of 3.5, also capable of 1A.
If I put 4 diodes and 3 XP-Es in series, that would be a theoretical max of 0.8x4= 3.2Vf, plus 3.5x3=10.5Vf, total 13.7Vf.
Let's say they balance out a little under their maximums:
4 diodes at 0.6Vf, (2.4Vf) plus 3 XP-Es at 3.4Vf (10.2Vf) equals 12.6 Total Vf.
A fully charged project SLA battery is 12.6VDC (minus any surface charge on the plates due to charging).
So, if I put these 4 diodes and 3 XP-Es in series, it SHOULD theoretically be okay to direct drive them, as the total voltage drop across all elements is either equal to, or more than, what the SLA can push through.
According to my ASE A6 Electrical certification, this makes sense. However, LEDs aren't part of that test, and I want to be sure I'm not missing something particular about the way they work.
Assuming my calculations are accurate, and the diodes drop the voltage around .6 each, and the LEDs drop about 3.4 each, according to Cree's Datasheet, that would have the Crees drawing about 800mA, through the entire circuit (well under the 1A limit of the diodes).
BTW, the diodes in question are part# 1N4004.
I know, I know, I should be using a CC driver, specifically built for driving LEDs, and there's always the resistor option, which performs a similar function in this application as the diodes. I know this is not the most efficient setup, and I'm not taking into account voltage sag on the SLA when presented with a load. I just want to make sure my logic and theoretical numbers are sound.
Thanks!
Thanks!
