ViReN
Hello All,
Its very simple (perhaps a dumb) question...
Following is the setup ....
Using a Inductor based Step Up Boost Circuit... (typical efficiency of 50 - 60%)
I/P = 4.5 - 6 Volts @ 100 - 800 mA
O/P = 45 - 70 Volts @ 5 - 40 mA
LED's are connected in Series (depending upon the configuraiton)
Case Condition
Schottky Diodes are expensive (as compared to Standard Diode)
Question
--> Is it OK to use a Standard P-N Junction Diode (which has a drop of about .6 Volts) instead of using a Shottky Junction Diode (dont know exact voltage drop.. but definately less than P-N Junction one) ? Especially when the cost difference is like 1 : 35 (p-n : Shottky) ...
--> What would be disadvantage of using p-n Junction... Is it possible to use a more ampere rating diode (may be 2 Amp etc)... or standard one amp will do ?
What I Feel
Since the drop is just of 0.6 Volts, as compared with the output voltage of 45 - 70 volts, is a insignificant drop... But, at the same time, since inductors are involved, spikes in o/p voltage are there and hence there might be a problem ... I am not sure and i doubt it.. & thats why.. this post /ubbthreads/images/graemlins/smile.gif
Thanks & Regards,
ViReN
Case Condition
Question
What I Feel
Thanks & Regards,
ViReN
