macrosloth
- Joined
- Oct 29, 2013
- Messages
- 5
I am trying to figure out how to build a driver for the MT-G2…
I am thinking of doing something similiar to below… I was thinking of doing 2 groups of amc’s first group of 12 for approximately 4 amps… second group of 8 AMC’s off a switch that parrallel the first group.
So when the circuit is first turned on the MT-G2’s receive 4 amps..
When the switch is flipped and the second group of AMC’s is turned on the MT-G2’s receive 7 amps.
At 12.2 volts about 1000 lumens per led.
At 4 amps I will need a supply voltage of approximately 13.4 volts before the AMC’s start to regulate current and heat up.
At 7 amps I will need a supply voltage of approximately 14.2 volts before the AMC’s start to regulate current and heat up.
When the supply voltage drops below 10.5 volts or so, the leds wont light up… I am ok with this…
Does anyone see anything wrong with this idea? Also could I add a diode/Resistor as noted with the question marks to protect the system from random voltage spikes? If so what..
Also how many milliamps would 20 AMC’s require on their green leg to turn on?
Also I guess I could install a voltage boost circuit before this if I wanted to keep the incomming voltage at about 14.5 volts..
http://s15.postimg.org/ft9iip623/Driver.jpg
