I just received my 1st SF this week which was an L2r and i ordered it due to my mass amount of AA rechargeable. But after seeing the quality they put into their lights id like to build one to my specs and accessories.
Here is my main problem i have a hard time wrapping my head around, Drop-ins.
Here is a the voltage options they carry at SF for P60's.
0.8-4.2V
3-6V
4.2-8.4v
4v to 18v
Im pretty sure im gonna go with a L2i body so i can use as many power options as possible.
Do the drivers in these drop-ins need to be matched as close to the maximum voltage ill be running? That way the driver sends the max amount of available voltage to the emitter?
If thats the case if i got the 4v to 18v drop in and i only used 6v would it be a pretty dim light as the driver would under-drive the emitter?
I know overdriving is bad no matter what.
0.8-4.2V with 1x18650 3.7v would equal almost max output of the emitter?
4.2-8.4v with 3x AAA 4.5v would be pretty much a dim light even on high?
Also, They show options to run 320Lms XPG R5 emitters at 18v but only 320 lumens.
Then they list a XM-L T6 Cree 820 Lumens that max out at 6v.
Is the R5 brighter than 320 lumens at 18v?
And does the XM-L have to be over driven to hit 820 lumens, say 12v?
Is my thinking on this close in how P60's work with different battery combinations?
0.8-4.2V
3-6V
4.2-8.4v
4v to 18v
